Help!!
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
last night before i adjusted the wheel, when the antilocks were kicking in, i could smell like a burnt smell. i figured that was from the brakes kicking in so often, i fixed the stearing last night and the antilocks do not kick in anymore, but when i got to work this a.m about a 5 mile drive from my house i still smelt that burnt smell, any ideas what that could be?? maybe i got some wd40 on my exhasut, idk... any experiences with a weird smell after lift??
![gak](https://www.jk-forum.com/forums/images/smilies/icon_crazy.gif)
If still using stock rims and tires it might be a tire rubbing. Happened to me. The rear upper control arm was hitting the tire. Stock rims didn't have enough back spacing. .
Sláinte
Sláinte
thanks, i dont think its my tires. i do have stock rims but i have the 1.5 wheel spacers on them. its not a burnt rubber smell more of a like wire burning or metal getting hot smell.. idk hard to explain.
If you still have the issue when you leave work, then I'd pull the wheels and inspect your assemblies, start with the front axle. It's likely that it's just leftover from yesterday and will diminish completely by the time you get home tonight.
thanks, im dropping it off at the alignment shop in the a.m hes going to check over my work and torque the jam nuts to spec since i could barely get any pull on them.
