07 jeep jk - Something is loose!!!!
Old Feb 12, 2014 | 04:13 AM
Fluid72's Avatar
Default 07 jeep jk - Something is loose!!!!
I have a 2.5 Budget Booster lift and treadwright 33's. When driving slow and mostly around turns, I can feel something loose. Feels like a clunking over small bumps, as if the the strut was not bolted down. I have replaced both struts, swaybar links, tie rod ends and the drag link (both ends). When the vehicle is up on a lift I cannot feel anything loose. I'd really like to figure this out before having to goto the dealer.
Thanks!!!!!!!!!!
Old Feb 12, 2014 | 05:05 AM
AirJordan613's Avatar
Originally Posted by Fluid72
I have a 2.5 Budget Booster lift and treadwright 33's. When driving slow and mostly around turns, I can feel something loose. Feels like a clunking over small bumps, as if the the strut was not bolted down. I have replaced both struts, swaybar links, tie rod ends and the drag link (both ends). When the vehicle is up on a lift I cannot feel anything loose. I'd really like to figure this out before having to goto the dealer. Thanks!!!!!!!!!!
I had a clicking/clunking sound after my budget boost install and one of my JKS swaybar link posts was loose. Not sure if your symptoms are the same though.
Old Feb 12, 2014 | 05:22 AM
jaker t5's Avatar
Look at your front shocks the nut on top sometimes comes off or loose
Old Feb 12, 2014 | 05:50 AM
planman's Avatar
Forum Tech Advisor
Have you read the first two posts and watched the YouTube videos in my write-up thread on Diagnosing Death Wobble and non-DW a Shimmies & Wobbles?
