Swaybar light
Old Feb 17, 2014 | 04:45 PM
PagosaGlen's Avatar
Default Swaybar light
I just replaced my Rubicon sway bar system with an Antirock. Of course the sway bar light now flashes constantly because it can't find the sway bar disconnect. I have a superchip flashpaq, is there an option somewhere in it to turn off the light?
If not what is the best option?
Thanks
Glen
Old Feb 17, 2014 | 06:14 PM
win1203's Avatar
I used AEV Procal to turn my light off.
Old Feb 17, 2014 | 06:25 PM
PagosaGlen's Avatar
Do you know if I can use the Procal when I am already using the Superchip?
Old Feb 17, 2014 | 06:26 PM
Flexer07's Avatar
Originally Posted by PagosaGlen
I just replaced my Rubicon sway bar system with an Antirock. Of course the sway bar light now flashes constantly because it can't find the sway bar disconnect. I have a superchip flashpaq, is there an option somewhere in it to turn off the light? If not what is the best option? Thanks Glen
I know many dread this and so did I. But it actually wasn't that bad. I took the gauge out and disabled it and took a knife and took the led out. Then reassembled it wasn't that hard to do and now I don't have the flashing light any more
It's the middle light on bottom row
Old Feb 17, 2014 | 06:31 PM
PagosaGlen's Avatar
LOL, wow that is extreme. I hope that is not the only way to get rid of it. You are a brave man.
Old Feb 17, 2014 | 06:33 PM
Ncb's Avatar
Ncb
It's not recommended.
Ncb's Avatar
Ncb
AEV Procal will disable the light.
Old Feb 17, 2014 | 06:34 PM
Garrett J.KU's Avatar
Originally Posted by Flexer07
I know many dread this and so did I. But it actually wasn't that bad. I took the gauge out and disabled it and took a knife and took the led out. Then reassembled it wasn't that hard to do and now I don't have the flashing light any more <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=531753"/> It's the middle light on bottom row <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=531753"/>
This is a really good idea when you pull abs and stuff
Old Feb 22, 2014 | 07:26 AM
PagosaGlen's Avatar
Got a Procal. It did turn off the Swaybar light and doesn't seem to have any issue with my Superchip. Success!
