Gobi Rack Squeak. suggestions?
Old Mar 11, 2014 | 07:23 PM
rdubb1031's Avatar
Default Gobi Rack Squeak. suggestions?
Have the gobi Rack for my 4 door. Whenever it's cold the contact point at the rear driver side body squeaks non stop. I tried adjusting the mounting, adding grease, changing rubber mounts. No luck.
Has anyone ran in to this? Any thoughts or suggestions?
Old Mar 12, 2014 | 04:42 AM
ZMagic97's Avatar
Hm...are the rubber "stoppers" cracked or dried out at all?
Old Mar 12, 2014 | 05:09 AM
Offroad_Elements's Avatar
Former Vendor
X2 ^
Can you isolate where exactly it is coming from?
Old Mar 12, 2014 | 05:15 AM
horrocks007's Avatar
Loosen, then re-tighten both the front bolts and the rear bolts. Mine squeaks a little at fridgid temps in the morning, but that's it.
Old Mar 14, 2014 | 11:27 AM
rdubb1031's Avatar
Originally Posted by Offroad_Elements
X2 ^
Coming from the stationary rubber stops below the pivot point at the rear of the rack. All rubber is new within 3 months.
