Onboard air
Old Apr 26, 2014 | 06:31 AM
46chevytruck's Avatar
Exploring options for onboard air for 35" tires after off-roading. I've seen the basic ARB compressors and they seem to take forever which just seems annoying. What are the other options? I've seen compressor/tank combos that fit between the engine and radiator and that seems to be a good option but I have no experience with them. Who has one, what brand, price and what is your experience with it?
I saw a guy with an onboard air system in Moab that was able to get a 37" tire to rebead after coming completely loose. Impressive but I didn't think to look at what he was running.
Old Apr 26, 2014 | 12:44 PM
Twinkydog's Avatar
Here is the setup I just built. I aired up my 35's from 16-32psi today and the tank pressure didn't drop below 75psi. It's not exactly OBA, but works well for me since I only need air for tires and tools.
https://www.jk-forum.com/forums/modi...-setup-301563/
AL
Old Apr 26, 2014 | 01:22 PM
nthinuf's Avatar
Probably some type of expensive York setup, check out Kilby airboss.
I didn't notice the date on this, I'm sure there are several better options available now, but it seems to be a good comparisson:
Tire Inflator Comparison
I have the ARB setup for the lockers/tires mounted under the hood, slow but does the job. Also have a 12 year old portable QuickAir 2 that I take along. (at some point, I'll probably mount it with a tank)
Old Apr 26, 2014 | 01:44 PM
Offroad_Elements's Avatar
Former Vendor
Here's my setup
ID:	548678   Click image for larger version
ID:	548679   Click image for larger version
ID:	548680   Click image for larger version
ID:	548681   Click image for larger version
Old Apr 26, 2014 | 03:18 PM
suprablaski's Avatar
Anyone running the warn powerplants that has used other dedicated compressors to compare performance? Since we're on the topic
Old Apr 27, 2014 | 05:45 AM
pontiac31's Avatar
I have a friend that has one, on his first trail ride we put together the air line kit and filled his four 35's from 12-35 faster then my cheapo HF did my 37's. It seems to put out a decent amount of air, but does seem to run really hot.
Old Apr 27, 2014 | 02:53 PM
LidLess07X's Avatar
I have the ARB with the brake master cylinder mount. Check out Powertank as an option with Springtail Solutions as a mount for it.
Old Apr 27, 2014 | 03:08 PM
briandunning's Avatar
I do, works great, but after spending 7 years spending 3-4 minutes per 35" I'm ready to look into something with a nice big tank. Also ready for someone to put central tire inflation on the market. ;-)
Old Apr 27, 2014 | 03:55 PM
A'sJK's Avatar
I have a Puma 12V. Not fixed mounted, but very fast. Central tire inflation would be cool though!
Old Apr 27, 2014 | 04:01 PM
. Where do you buy a puma?
