jcr rock slider install
Old Apr 26, 2014 | 12:27 PM
detonatoryel4x4's Avatar
So far install is going smooth but time to drill into the body hope this goes well
ID:	548657   Click image for larger version
ID:	548658   Click image for larger version
ID:	548707   Click image for larger version
ID:	548708   Click image for larger version
Old Apr 26, 2014 | 05:35 PM
Invest2m4's Avatar
Step drill bit is the way to go. Using a regular bit is bad news.
Old Apr 27, 2014 | 01:25 PM
Tomsryt's Avatar
"Step drill bit is the way to go. Using a regular bit is bad news"
I used a pair of "cowboys", vice grips with the wide mouth, to keep it safe for a regular high-speed drill bit.
If I didn't have them though, I would have gone the step-bit route.
Old Apr 28, 2014 | 07:35 AM
I wish I thought of the step drill it turned out good but was a pain to get lined up just right. Has any one used a sealant to help prevent rusting behind their sliders?
Old Apr 28, 2014 | 07:44 AM
Rob 12B1P's Avatar
As thin as the bodies are on these things you could probably get away with a hammer and a sharp nail
Old Apr 28, 2014 | 07:47 AM
suprablaski's Avatar
Paint your drilled holes and you will be fine, just don't want the exposed metal
Old Apr 28, 2014 | 08:38 AM
Invest2m4's Avatar
I've asked a couple manufacturers and they both say not to seal. It essentially traps moisture where you want it to breathe.
Old Apr 28, 2014 | 10:44 AM
Thanks for the heads up. I'll just be sure to touch up the holes with paint as best as I can.
