Recommendation for front winch Bumper for 2012 Rubicon?
Anybody have Recommendations for front winch Bumper for 2012 Rubicon? I looked at Rugged Ridge XHD but it requires relocating vacuum pump? Also you can't replace fog lights if they burn out too easily.....
some sunk and hidden others deck mounted , I realy am very pleased with the posion spyder mid front bumper I just got put on . and if I add a winch at some point , no plates , or anything is needed . these are solid . its like armory . optional elec disconnect skid is a good piece of mind as well . Oh and fogs you just use the oem.
I have the LoD Signature Mid-width. Allows use of the factory fogs placed somewhat wider that the factory configuration, which I like.
I wanted the winch to sit all the way down in the bumper for airflow and protection. I also remotely located the solenoid. Works great and has held up very well.
My poison spyder brawler lite was a breath of fresh air to install - very pleased with it. You do not have to relocate or drill anything, simply mounts up. The only thing that might turn people off is that you have to have it painted. I had mine powder coated with a wrinkle finish and it looks great.
Also will accept factory fogs or any of the after market designs. I put rigid Duallys in mine with the brackets.
