Just towed away
Old May 17, 2014 | 08:35 AM
USMC03's Avatar
Default Just towed away
Had it since feb 2014 pulled into work this morning and moved it to another spot and found this, i called the dealership and they sent for a tow
Old May 17, 2014 | 08:40 AM
jaker t5's Avatar
Attachment 553522
What are you seeing in that picture that is bad , did you look under the jeep for any actual leaks
Old May 17, 2014 | 08:41 AM
USMC03's Avatar
Oh ya the dealership called for a flatbed so when it came and was getting loaded at an angle it was pouring out
Old May 17, 2014 | 08:42 AM
jaker t5's Avatar
What was leaking out
Old May 17, 2014 | 08:45 AM
USMC03's Avatar
Oh ya they had it at an angle loading it onto a flatbed and oil was just pouring out
Old May 17, 2014 | 08:50 AM
jaker t5's Avatar
Well good luck and keep us posted what happen , I question the picture because I see a bunch of different areas where it look like something happen it's just a really big area and spread out
When was the last time you had a oil change blow back of oil and then dripping on the ground could make those spots
Old May 17, 2014 | 08:52 AM
USMC03's Avatar
I haven't had any service done or work done on it, it just hit 2k miles
Old May 17, 2014 | 09:26 AM
jaker t5's Avatar
I just saw this
https://www.jk-forum.com/forums/stoc...-303650/page3/
Old May 17, 2014 | 10:01 AM
Tooadvanced's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=553522"/>
Probably that oil filler connection ppl are talking about breaking on 2014s.
Old May 17, 2014 | 11:17 AM
USMC03's Avatar
Just heard from the dealership and thats exactly what is was, cracked oil filter connector most likely over tightened at the factory
