Death Wobble
I have been experiencing a very rough shaking, it only occurs while doing 50-55 mph and making a turn on the highway. Is this the death wobble that I read about? If so, what can I do to remove it?
Sent from my SM-G900V using Tapatalk
https://www.jk-forum.com/forums/jk-w...obbles-260145/
Ok so I haven't experienced a full on death wobble yet but I've got a problem and looking for some advice.. 25k miles on my jku 3.5 coil lift factory shocks and steering stabilizer 35" tires and everything else stock except springs and longer sway bar linkages... At low speeds hitting big bumps causes a few seconds of a slight/moderate wobble in the steering I don't think with this low of mileage anything should be worn enough to cause the wobble but the steering stabalizer.. Any advice? I don't want to prematurely replace the stabilizer and mask a more serious issue..
Also, with a 3.5" lift, I think the stock shocks are most likely bottomed out. You should get shock extensions or new longer shocks to accommodate the extra lift you have.
