5.13 Gears 37inch MTR shifting issues
I just recently changed to 5.13s and 37inch Wrangler MT/R W/Kevlar. I have a BullyDog GT Tuner that is set 5.13s gearing and 37.2 inch tires on the stock setting. I have noticed shifting lag on inclines and on the flat it seems to shift early. I find that often I have had to feather the throttle to get it to shift. Has anyone experienced this? It is starting to become annoying.
I actually disconnected my battery when installing my snorkel I am running the Bully Dog Gt with 35" MT/Rs before disconnecting the battery it would hard shift after i disconnected it for several of hours i found that it shifted smooth again. Could be coincidence I dont know but worth a shot
I found data that claims the Good Year MT/R 37s are actually 36.8. The Bully Dog does not have a setting to 36.8 so I set it to 36.77 and it seems to shift better without the need to feather the throttle. Thanks for the input.
The 36.8 is the unloaded height when mounted on a nominal wheel width. You should use the measured diameter once on the Jeep for the best shifting and most accurate speedo
