JK Rear Axle locker connector
I managed to snag the rear locker connector (the upper connector that connects to the coil) on a branch, and damaged the connector. I'd like to replace the connector, but I can't find any documentation that tells me what the part number is for that connector.
It's attached to the axle with an 8mm bolt. Does anyone have any information on this? I have the same axle in my TJ, and I have the same problem with that axle.
ThanX!
ThanX!
I had to replace mine on the axles I bought a couple of months ago, as it got damaged in shipping. I got it at the parts counter at the Jeep dealership. It was a little over $30. It just connects to the wire harness, and is held to the axle with the one little bolt. Be sure to lube the o-ring before reinstalling. Makes it easier. Sorry I don't have the part number. He just pulled up the diagram on his parts computer and I pointed to what I needed.
Here it is:
Jeep Part 68003570AA - Actuator Connector - Fits 2007 to 2014 JK Wrangler, Rubicon and Unlimited - 4 Wheel Drive
In the diagram it shows it to be a different piece, but this is the connector that bolts into the axle.
I spliced the wires together (there was enough to play with) on the front when mine got ripped apart, which was 3 years ago, all it cost was 1'' of solder, and 3''s of shrink wrap...
Here it is:
Just to confirm .. This is the connector. (Part I need) ?
2007 Rubicon /2 door/6 speed
Correct. It points to a different part in that particular pic. But if you scroll to the top of that original web page, you will see the entire exploded view with the right part indicated.
