what's the height of your rig?
I have a aev 2.5 lift and 35's sitting in garage and nervous about it fitting in my garage after its all on. So anyone running similar setup and what height you sitting at.
Easier question is what is height of your garage. I have a small garage and with soft top which is 2-3 inches higher fits with room to spare.
Maybe I'm over thinking it, but why not just measure you jeep, then break out a calculator to add the height of the lift and tire change?
Current height, plus 2.5-3" for the lift, plus another (stock 32", new 35", 3" difference, take half of that number) 1.5" for the tires. So stock height +/- 4.5".
And there are differences in height by JK model/setup, and differences in tires from different mfg's, and differences in tires of different rim sizes from the same mfg, and, and, and...
Seems like the same answer to me. Start with your stock measurement and your garage door height, not someone else's.
