drag link options??
Old Jul 13, 2014 | 06:13 PM
lowendrider's Avatar
Default drag link options??
Had a lot of "fun" today trying to track down a shimmy. Turns out the axle side trac bar was loose. The nut had seized on the bolt and I didn't realize it, so the last time I had it off and then torqued it down, it torqued alright, just not tight! Incredible pain in the arse to get off. Anyways, dealt with that so heres the question...
While I was giving everything a good going over, the only other problem that I could see was that the drag link on the knuckle side had some up and down movement. Not terrible, but I know its not supposed to do this. What are my options to replace? Don't want to spend mega bucks and don't need a flip kit. Also don't want another crappy factory joint. Opinions??
Old Jul 14, 2014 | 02:02 PM
Firelyle's Avatar
I put the Synergy link on mine and it's a very sturdy unit. Works in either the standard or flip position. It's not cheap but you get what you pay for and I don't think it will need replacement any time soon. Good luck.
Old Jul 14, 2014 | 02:55 PM
Offroad_Elements's Avatar
Former Vendor
Synergy on mine! Like stated above, works great in either stock or flipped position, easy to adjust, and one of the strongest DL on the market!
Contact us any time for forum member pricing!
Old Jul 14, 2014 | 03:10 PM
nthinuf's Avatar
Another vote for synergy. I ran it in the stock location for quite a while before finally getting around to adding the bracket and flipping.
Old Jul 14, 2014 | 03:28 PM
JayswranglerX's Avatar
That's the one I'm going with when I do my flip.
Synergy\poly is top notch
Sent from my LG-LS980 using JK-Forum
Old Jul 14, 2014 | 03:58 PM
kjeeper10's Avatar
Vet Army
Synergy or RK's new pro drag link if ya have tow strap and what to pull down a house with it.
Synergy for the win
2007 Rubicon /2 door/6 speed
Old Jul 14, 2014 | 04:18 PM
Synergy for the win
That's a fine set up you have there sir....any discernable difference with the ATS stabilizer over normal ones?
Old Jul 14, 2014 | 05:19 PM
Thanks for the replies. Does the Synergy require you to drill the knuckle out when using it in the stock location? Also, I have the Dominion steering stabilizer relocation bracket..any clearance issues?
Old Jul 14, 2014 | 05:29 PM
nthinuf's Avatar
Drilling is for the flip. Stock location is stock location, remove the old one and bolt up the new one.
Old Jul 14, 2014 | 05:37 PM
10-4...I'll have to save some coin and upgrade when the factory gets worse. Thanks again for the info.
