Grill Mod F-up
Old Jul 17, 2014 | 09:46 AM
tsaylor1979's Avatar
Default Grill Mod F-up
I was done (or so I thought) with my duplicolor paint job on my grill. I had it set in my driveway to finish drying and a piece of paper landed and stuck to it. When I took it off, it left a mess of duplicolor underneath it. Will I be able to sand it off and re-paint or should I just look for a new grill now?
Old Jul 17, 2014 | 09:51 AM
Grant09's Avatar
Wait for it to dry completely. Sand it down until the problem area feels smooth. Repaint that spot. I think that'll take care of it, however I'm not an auto body expert or anything.
Old Jul 17, 2014 | 09:56 AM
TheNoob's Avatar
Try using paint thinner on a clean rag and rubbing that spot then re-spray the area. If not you can use a fine grit sand paper and re-spray, you shouldn't have to remove all of the paint.
Old Jul 17, 2014 | 06:19 PM
PF20's Avatar
Shoulda used plasti dip, coulda peeled it right off!
Shoulda coulda.
Old Jul 17, 2014 | 09:12 PM
Mountain Man Tim's Avatar
i tried to buy some plasti dip in town the other day, no one carried it out of 5 places. the one place that knew what it was said they hadnt recieved any new stock since the 90s........
Old Jul 18, 2014 | 04:48 AM
Flexer07's Avatar
I agree what till it drys then sand it down. Make sure you use a sanding block and feather it out (don't stay in that one spot) so it won't have waves
Old Jul 18, 2014 | 04:19 PM
Sanding worked. Time consuming but it got the job done.
If anyone does this, wait until you know ALL of it is completely dry before you set it outside.
