lift help please
Old Jul 17, 2014 | 02:52 PM
immortalmetal's Avatar
Default lift help please
If I'm doing a 2.5" lift, do I have to loosen the control arms? Upper and lower?
Will it need aligned afterwards or will it cause death wobble afterwards?
I didnt loosen the bolts for them before with my '11. But I'm reading write ups where they say to loosen the bolts.
Do I need to? And will it mess up alignment?
Thanks. I'm doing my lift tomorrow morning
Old Jul 17, 2014 | 03:04 PM
DunnyBunny's Avatar
JK-Forum Ambassador
You loosen the bolts to take bind off the bushings. Loosen all the control arm and trackbar bolts give the jeep a good shake and then retorque all to spec.
Old Jul 17, 2014 | 03:05 PM
jadmt's Avatar
JK-Forum Ambassador
it is a very good idea to loosen all control arms front and back and leave them loose until jeep is back on its own weight. I bounce the crap out of mine before final torq.
Old Jul 17, 2014 | 03:07 PM
Its okay to set it down on the ground while those are loose?
Thanks for the info everyone!
Old Jul 17, 2014 | 03:11 PM
kjeeper10's Avatar
Vet Army
Yes ... The weight is on the coils. You can support under the axles if you need more space to torque.
I like to use a long breaker bar in place of a wrench to hold the bolt from spinning. HF was selling this for $12
2007 Rubicon /2 door/6 speed
Old Jul 17, 2014 | 03:14 PM
nthinuf's Avatar
You want it on the ground, under full vehicle weight.
Old Jul 17, 2014 | 04:32 PM
K, now when I lift the front end, do you lift from the offset pumpkin? Or directly in the middle on the actual axle?
I think last time I lifted from the pumpkin. But the drivers side always lifted up more than the passenger. Would there be any harm in lifting from the axle?
Old Jul 17, 2014 | 04:53 PM
Billbikes's Avatar
You might have to disconnect the Track Bar to get the axle to drop far enough to get the new springs in. As said before, loosen all your control arm bolts, and retorque after the Jeep is back on the ground sitting on it's own weight.
I imagine this is just springs? Do you at least have shock extensions?
Make sure you disconnect the Brake line brackets from the frame, along with the ABS wires! In the rear, same thing, but you have to drop the E-brake cables out of the hanger. Check brake lines for clearance when your done.
You can lift from the Diff, but it won't lift even. I wouldn't lift from the axle tube. It's easiest if you have two jacks, but if you don't, do it in steps, one side at a time, lifting from the control arm bracket.
Old Jul 17, 2014 | 04:57 PM
This a coil lift with the shocks. I did the budget boost with shock extensions a few years ago on the '11.
But I'm just curious if I can lift the front end by the axle or if its too unstable. Lifting the the pumpkin is ideal, but its offset location makes the jeep lift up awkward.
Also, last time I reattached the rear ebrake cables to the tub of the jeep. Was I not supposed to? Doesn't seem right for them to just float around under there and rattle. ?
last time I also didn't loosen the control arm bolts. I'm trying to do everything right this time, and safely.
Thanks for the input!
Old Jul 17, 2014 | 05:00 PM
Do in steps meaning lift one side at a time till the whole front end is up in the air? Or do one side at a time meaning, lift one corner take out spring and shock and install new ones. Then set on ground then do other aide?
