Lift Kit and ???
Old Jul 17, 2014 | 08:50 PM
garrettuecker's Avatar
Default Lift Kit and ???
Looking to throw a 4" lift kit under the JK and curious what all needs to be done with that. Will there be parts that need replaced? I am mechanically helpless so any and all advice is appreciated, cost, brands, etc.
Old Jul 17, 2014 | 09:22 PM
afpilot82's Avatar
JK-Forum Ambassador
Please, start with these 2 threads...
https://www.jk-forum.com/forums/modi...-lifts-288269/
https://www.jk-forum.com/forums/modi...bie-has-18617/
Old Jul 17, 2014 | 11:06 PM
nthinuf's Avatar
Lol, talked about and linked in his last lift thread.
Obviously, blurbs like these are no help whatsoever in answering the question of what parts to consider replacing...
Q: What are all the components that I will need with a 3" lift?
Q: What are all the components that I will need with a 4" lift?
Q: What is Caster? How much do I need?
Q: Why do I need an adjustable front track bar?
Q: Are there any write-ups on how to install a lift on my Jeep JK Wrangler?
Q: I just installed a lift on my JK. Do I need an alignment?
Q: Is there a good chart that I can refference to help me determine what gear ratio I should have installed based on the tire size I am running and the RPM's that I hope to be running?
And that is just the faq's. I wonder if there might be some useful information in the other one. Somewhere. Maybe? Nah, doubt it.
But at 4", look in to:
Some form of caster correction. (brackets/cam bolts/fixed arms/adjustable arms)
Some form of axle centering. (brackets/adjustable trackbars)
Some form of steering correction. (high steer/drag link flip/drop pitman)
Some way to get slack in to the brake lines.
Bumpstops.
Driveshaft(s).
Old Jul 18, 2014 | 06:30 AM
TeraFlex's Avatar
Sponsoring Manufacturer
First off, what size of tire are you planning on running?
Old Jul 18, 2014 | 09:19 AM
TheDirtman's Avatar
Trust me, you don't really want a 4" lift unless you are going to be running 40"+ tires. And if that is your plan then god help you.
Old Jul 18, 2014 | 09:43 AM
MikeRM's Avatar
Not knowing your plans and off-road skills, this is my opinion. I started off-roading stock and now have a TF 2.5 spring lift with 34" tires. In that range of lift & tire size, my Jeep is way more capable off-road than I have the guts to take it. I am a novice with Jeeps, but have wheeled trucks quite a bit.
