Will 10 miles??? kill my tires
I just bought a daystar 1.75 spacer lift for my two door rubi. if i install it at home can i drive to the alignment shop which is roughly 10 miles down the road without destroying my tires?
I put a 2" Rancho lift on my JK and didn't require alignment. Your jeep shouldn't need anything. Tow is the only thing that is adjustable.
The toe-in should not change with the lift. Caster is not adjustable with stock control arms. Camber can't be adjusted at all. Just center the steering wheel.
