Towing
Old Jul 21, 2014 | 08:54 AM
Mudfire's Avatar
Default Towing
I have a 2007 jk Sahara unlimited 2wd, I wanted to know if I could tow a 22' boat? Any suggestions
Old Jul 21, 2014 | 09:07 AM
tarpon4me's Avatar
JK-Forum Ambassador
2WD? SHAME ON YOU!
OK, now that I got that out of the way, it depends on what kind of boat. For instance, I tow a 19' carolina skiff with my JK with no problems. It probably has a wet weight around 1900 pounds. There is one ramp I need 4L to get it up because of how steep it is, but normally inclined ramps it's fine in 2WD. A 22' bow rider, center console, or deck boat is going to be heavy as balls. My buddies 21' Hyrdasport is over double the weight of my boat, and if that's your scenario, don't even try it.
Old Jul 21, 2014 | 11:18 AM
davegill's Avatar
I have a 07 jk with 37's and drag a 21 nautic star bay boat a lot..no issues unless I'm climbing a steep bridge or a steep hill then it's downshift time lol
I'm running a 6 speed
Old Jul 21, 2014 | 01:19 PM
nthinuf's Avatar
If it is over the 3500lb limit, there may be some liability issues to worry about. But I have dragged a boat and loaded uhauls that weighed somewhere in the 3-3.5k range on 10+ hour freeway trips with no issue. (other than the general gutlessness of my 3.8 auto...)
Old Jul 21, 2014 | 02:15 PM
zong4200@gmail.com's Avatar
I have an '08 and tow a 20 camper. I run 35 on mine and I have the 373 gear ratio. I put electric brakes on mine.I would suggest putting a dedicated transmission cooler . I have no problems unless its a steep grade
Old Jul 21, 2014 | 04:33 PM
D3ADLY's Avatar
I pulled a 21' camper that I was told weighed a little under 4k lbs. I have 37's and 4:10 gearing at current. It wasn't to bad until I hit a hill. After it down shifted I couldn't hold speed much over maybe 45 mph. Give or take a little. Been a little while now since I towed it. I wouldn't recommend doing it all the time with a setup like mine.
Sent from my Go Go Gadget handheld device.
Old Jul 23, 2014 | 08:29 PM
Smitty12JKU's Avatar
What is your tire size and gear ratio?
