Rack Lights
Old Aug 1, 2014 | 08:45 AM
Jeep066's Avatar
Default Rack Lights
Just purchased a set of racks for the Jeep. Interesting in adding some LED lighting for the sides and back it have when camping. I have no idea how i would run the wires for this. Any ideas?
Old Aug 1, 2014 | 12:39 PM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Are you opposed to drilling holes in the rack to feed wire through?
Old Aug 1, 2014 | 05:26 PM
5150cliff's Avatar
If you're not familiar with hooking up electrical stuff, you may want to find someone who does to help you. It's going to be difficult to try to explain wiring technique over this forum. I'm assuming you're concerned how to hookup to switches and relays correct? Can you give more detail of exactly what help you need?
Old Aug 2, 2014 | 12:48 AM
Mark Doiron's Avatar
It would be helpful to know specifics of the rack. I have an MBRP rack with the optional front extension. I drilled a hole in the curved sheetmetal plate just driver's side of the hood cowel and put a rubber grommet in there. The rack tubing comes to an end there and has a plastic cap in it. Drilled hole in plastic cap and put another rubber grommet. Ran wires from the sPOD, through the fender hole, through the plastic plug, and from there it's hidden. Ran to overhead lights and out existing holes (for such purposes) on the rack--but could have drilled more holes and added more grommets.
A little about the wiring: I buy wiring materials from a local supplier, but they do sell online. I took the wiring and use heat shrink to dress up the ends of the loom. I also use WeatherPak connectors at each light assembly--make removal to work on one easy. There is also a WeatherPak at the fender to rack loom so that if I remove the rack, I can just leave the pigtail wiring hanging out (it's hidden by a bracket mounted there for doors-off mirror mounting). It's dark out right now, but here are a few pictures that may help you get a better idea.
sPOD controller ...
sPOD wiring ...
Overhead lights ...
Crop of above image to better show where wiring comes through fender ...
I have a busy Saturday, but can add a good picture of the fender to rack transition, or whatever else you might need. To ensure I don't miss a post in this thread, message me and I'll get on it by Sunday. :-)
And here is where I buy wiring and loom and such. They sell short lengths retail--contact them for more info ...
Spectro Wire and Cable: GPT Primary Wire
Spectro Wire and Cable: Expandable-Sleeving
Spectro Wire and Cable: Adhesive Line
Spectro Wire and Cable: Weather Pak Connectors
Name:	Jeep Work, Sep 13, 5_9826, Engine Fan Switch.jpg
ID:	568869Click image for larger version
Name:	Jeep Work, Sep 13, 5_9833, sPOD.jpg
ID:	568870Click image for larger version
Name:	Verdant Jeep Images, Jun 14, 4886, Jeep at Home.jpg
ID:	568871Click image for larger version
Name:	Verdant Jeep Images, Jun 14, 4886, Jeep at Home (temp crop).jpg
Old Aug 2, 2014 | 07:29 AM
Hah, a brief lull in the action--got the work at my church done more quickly than I anticipated, so washed Jeep and shot a couple more pics of my wiring ...
At the light bar ...
At the interface between the cowel and the overhead rack ...
Again, the bracket that you see to the right of the cowel is for mounting a TJ mirror to my Jeep when running doors off. I leave the bracket in place to protect the nutserts holding it from spinning out (had a problem with that in the past).
Name:	Jeep Overhead Lights, Aug 14, 1964, Light Wiring.jpg
ID:	568884Click image for larger version
Name:	Jeep Overhead Lights, Aug 14, 1967, Cowel-Rack Interface.jpg
