33's or 35's with terreflex kit
Old Aug 1, 2014 | 04:09 PM
c-izzy's Avatar
Default 33's or 35's with terreflex kit
Hey all. Just put a 2" in front and 1" in rear terreflex leveling/lift kit. Question is can I get 35's on it now or do I need 33's? Also if anyone has pics of that setup it'd be appreciated.
Old Aug 1, 2014 | 04:10 PM
Jeepstercanada's Avatar
I know ppl who have run 2 inch terraflex budget boost with 35 and flats with no issues
Old Aug 1, 2014 | 04:52 PM
jadmt's Avatar
JK-Forum Ambassador
I had the 1.5" performance coil kit on my 2013 jku and no way could you go 35's without flat fenders.
Old Aug 1, 2014 | 05:08 PM
Ncb's Avatar
Ncb
The leveling kit doesn't change the overall travel of the suspension from stock. 33s will slightly rub and 35s will remove the flares at full stuff.
Simply adding spacers only changes the ride height.
Old Aug 1, 2014 | 05:12 PM
Ncb's Avatar
Ncb
This was prior to a lift and 35s.
It was the TF leveling kit and 285/70/17 KM2s. The fronts had a very minor rub at full stuff. Sounded horrible, but never had any damage.
Old Aug 1, 2014 | 05:23 PM
wheels777's Avatar
Depends entirely on your wheel offset and width and what your going to do with it. My pintlers fit Terra Grappler 35x12.50s without rubbing anything at stock height for any normal street use.
But as mentioned above, only by adding bump stop height will you be able to prevent rubbing with any enlarged tire and stock fenders.
Old Aug 1, 2014 | 05:25 PM
BlackRockBurner's Avatar
OP- do you wheel or is for looks? 33's will have minimal impact on performance in acceleration, mpg and braking. 35's will increase your running ground clearance over stock by 1.5" but you take a hit on acceleration, mpg and braking. It's really your call.
Here are pics of 33's and 35's on a 2.5" lift to give you a idea.
ID:	568845   Click image for larger version
Old Aug 1, 2014 | 06:57 PM
jay01th's Avatar
Default 33 or 35
Go with your 35 inch tires, I used 15 inch Alloy rims that cost 100 bucks online and a 2.5 inch Rough County Lift
Old Aug 1, 2014 | 08:44 PM
sea bass's Avatar
My brother just put a leveling kit, 17" fuel trophies, and 35" km2's on his jeep. Looks great! Just need to add some bump stop
Old Aug 1, 2014 | 08:45 PM
whipple281's Avatar
How far off did the 1.5" throw off your caster/pinion and how far did it off center your axels? Did you have to add anything else to the kit like sway at end links, track bar etc?
