2008 JK stock rear tire carrier bouncing
I've checked the mounts and they are tight. 33" tire mounted on it. Any bump I hit makes the tire bounce around pretty bad. Looking for a quality rear tire carrier/bumper combo but until I get it any suggestions to stop the tire from bouncing around? Anyone else have this problem? Suggestions on a good tire carrier/bumper would be appreciated. I like the look of the Smittybilt but several reviews were pretty bad. Thanks.
Thanks. I'll make sure to check it. I saw a few reviews about the craftsmanship and overall quality of the Smittybilt XRC that make me wonder but I may give it a try. Thanks again.
I plan on getting the OR-FAB tire carrier with rotopax only downside is it doesn't have an attached bumper but you can buy a metal one.
Hi
Have You checked that your tire is tightly flushed against the rubber stopper. This is mandatory. I feel that a 33" should not bounce around if it is flushed against the rubber stopper.
I hade to put a sturdy rubber hose in mine because the where to short with my 265/70/17 tires and 4.5 backspacing rims.
Have You checked that your tire is tightly flushed against the rubber stopper. This is mandatory. I feel that a 33" should not bounce around if it is flushed against the rubber stopper. I hade to put a sturdy rubber hose in mine because the where to short with my 265/70/17 tires and 4.5 backspacing rims
My welds are kaput... should have put a carrier on months ago. TRUST US, It'll only get worse. I have a 33" nitto trail on the back and it vibrates like hell on rough roads. I've been cringing for 6 months, XRC comes in this week.
