OME LIFT Trouble
Old Mar 2, 2008 | 04:31 PM
AussieJK's Avatar
Unhappy OME LIFT Trouble
I ve just installed my ome lift gained a true 2.5 inch lift and my 35's are scrubing everywhere anyone else had these problems im runing offset rims as the arb dealer recomened but still rubbing all help is greatfull.... ps front only rubs with front disco's undone which i can understand but im not so impressed they said 35's would clear nicely even at full travel, arse holes lied anyway thanks guys
Old Mar 3, 2008 | 04:52 AM
swampdonkey's Avatar
I have the HD kit, but I did not install the spacers that came with the kit. I will be putting them in next week since I do still have a rake. Here were my measurements before and after to the bottom lip of the fender (center line of axle)
Before:
Front: 35.5
Rear: 37.5
After OME:
Front: 39.5
Rear: 40
I have not put on 35's yet, but I plan to do so. I should not be rubbing. Did you get the HD kit?
Old Mar 3, 2008 | 05:34 AM
Beancounter's Avatar
Have 4 dr with kit and have no rubbing.
Old Mar 3, 2008 | 03:12 PM
AussieJK's Avatar
Default hd
Yes hd springs were fittet with the spacers also... i have the arb front and rear bar and rock sliders no winch yet so im confused as much as you guys are i might take it down to were i got it from they might have packed the wrong springs in it
Old Mar 3, 2008 | 03:14 PM
AussieJK's Avatar
Default back spacing
I have 1.5inch back spacing on it...
Old Jun 5, 2008 | 03:18 PM
bmcqueen's Avatar
bump.........
Old Jun 6, 2008 | 07:32 AM
Northridge4x4's Avatar
Sponsoring Vendor
So all you are saying is on full flex the front Tire rubs the fender? If so that is a easy fix put a extended front bumpstop in and you are good to go.
David
Old Jun 6, 2008 | 08:25 AM
robin's Avatar
unless you limit your flex 35s will rub at full flex even with 4 inches of lit.
Old Jun 6, 2008 | 12:01 PM
G16's Avatar
G16
You may need more backspacing on the wheels.
Old Jun 7, 2008 | 07:59 AM
envied4x4's Avatar
Hi i got the OME lift and got about 4'' but i do rub at full flex i have the HD kit with stock stubby and stock wheels with spacers and 35''s, i think we have to get bump stops.
