Rubicon shocks and springs for my sahara
Old Sep 20, 2014 | 05:50 PM
bhuggins07's Avatar
Default Rubicon shocks and springs for my sahara
Hi,
I've got the opportunity to pick up some shocks and springs off a 2014 rubicon unlimited for my 08 Sahara unlimited. Is it worth it? Would that give me any lift at all?
Thanks in advance.
Old Sep 20, 2014 | 06:06 PM
Tripletsi's Avatar
Compare the spring rates. Usually you'll get .25 inches every number you increase. The Rubi shocks are nice, not a bad upgrade if its cheap.
Old Sep 20, 2014 | 06:07 PM
kmrtnsn's Avatar
Originally Posted by bhuggins07
Hi,
Thanks in advance.
Not really. If you had a 2 door, then you might gain some lift if the spring rate is greater on the donor JKU but from JKU to JKU you'd more than likely be trading 18/59's for 18/59's; the same springs resulting in no lift gain, and no performance gain either. The red Rubicon gas shocks are better but check your shocks first.
Old Sep 20, 2014 | 09:37 PM
Mountain Man Tim's Avatar
You will get a better ride, but not much lift as mentioned. The red rubi shocks look awesome though, especially if your jku is red.
Old Sep 21, 2014 | 03:51 AM
AngryRedBird's Avatar
I was actually searching for a set of slightly used red rubi shocks.. before Daystar stepped in.. Cause Daystar could have sent just the spacers and left the shocks up to me to find.. I did find several jeepers that had upgraded their shocks.. but I wasn't about to put a set of 30K mile shocks on the jeep.. assuming that was an actuate mileage reference for those shocks.. So yes I was surprised that Daystar sent a full kit which included the shocks..
Old Sep 21, 2014 | 04:01 AM
14Sport's Avatar
^This. Depends on what you're starting with.
Old Sep 21, 2014 | 06:45 AM
Tripletsi's Avatar
How so?
The first thing I suggested was that he compare spring rates. A higher (stock) spring rate is a higher (stock) spring rate no matter which way you look at it...
Old Sep 21, 2014 | 06:48 AM
14Sport's Avatar
How so?
I was agreeing with you. That's what "^This" means. Depends on what coils you start with. Switching out the same coils will gain nothing.
btw, I just checked my wife's 2012 fully loaded Sahara JKU and it has 16/59s. Seems like an odd combo.
Old Sep 21, 2014 | 07:16 AM
Tripletsi's Avatar
Ahh I see. Gotcha. I was reading it as "This depends on what you're starting with" which had me confused. I thought the ^ was just in reference to my post. No foul, no harm.
Old Sep 21, 2014 | 07:22 AM
14Sport's Avatar
The "depends on what you're starting with" was for the OP. A further elaboration if you will.
