anyone running poly bushings
Just wondering if poly bushing make your jeep feel tighter more like new? what else can you do to tighen up the ride more like new?
about my jeep its an 08 4dr rubicon with a 3.5 ome lift auto warn bumper and smitt 10k winch bilstein shock ome heavy duty springs terra flex trac bars up front.
any thoughts?
any thoughts?
I want you to check something out.. Although this is not about a jeep.. It is about a mopar product..
Energy Suspension Performance Polyurethane Bushings Comparison Photo 5
Poly does work well but don't fool yourself if you think they won't need replacing. Poly urethane will pack out over time, often starts cracking as well. The company I work for has a number of patents with Many materials as well as urethane. Urethane is good but not immune to the same issues.
I forgot to mention. I installed urethane bushings on my Volvo motor mounts. Sure, they absorbed more vibration. But, anytime you soften urethane, it has more oil and other additives added in to soften the matrix and it leads to quicker wear.
The mounts worked great but I replaced far more often than rubber motor mounts. About 1 time a year on average.
And, in the cold, urethane is very susceptible to being affected by temps. Cold, they get really stiff.
Silicone would be best. But I don't know if anyone has silicone available for this application.
