Differential Cover Options
Old Oct 3, 2014 | 05:20 PM
BCT's Avatar
BCT
Default Differential Cover Options
I'm looking to swap my factory Differential covers with an aftermarket brand... I have a 2014 Rubicon Unlimited with Dana 44s and would like to get Poison Spyder models. I have a JKS adjustable Front track bar installed as well. I also have a 2.5" lift with correction brackets installed. Will I have any contact issues with the PS Diff Covers with my current suspension setup?? I read someplace that with the JKS trackbar installed there may be some rubbing issues. Any additional recommendations are appreciated. Thanks BCT
Old Oct 3, 2014 | 05:37 PM
orngkrate's Avatar
I have Ruff Stuff covers, 2.5" RK and the JKS Adj track bars with no issues on '12 JKUR
Old Oct 3, 2014 | 07:38 PM
Rob50lx's Avatar
Have you extended your front bumpstops?
Sent from my d2lte using Tapatalk
Old Oct 3, 2014 | 07:39 PM
orngkrate's Avatar
Yes I have
Old Oct 4, 2014 | 07:00 AM
orangedude71's Avatar
I went with the poison spider in the rear and in the front just put a diff guard on as I wanted to avoid any interference problems. I honestly think most of the protection comes from stiffening the edge of the stock cover from peeling back more than adding a giant cast iron lump on the diff.
Old Oct 4, 2014 | 10:57 AM
mikeJKUR's Avatar
which diff guard are you using?
Old Oct 4, 2014 | 12:59 PM
Cat Dr.'s Avatar
Default Diff cover and guards.
I used the ARB and have no issues with rubbing. I later installed a Rancho front diff skid plate. I did have to modify it due to the fact that the upper bolts do not line up with the ARB cover. I agree with the above in as much as if you use a good skid plate the factory covers would probably be fine.
Old Oct 4, 2014 | 01:07 PM
Jersey_Devil's Avatar
I run an ARB and have no issues with it.
sent from my obama monitoring device
http://www.quadratec.com/products/92023_100.htm Two trips through rubicon with no leaks. My buddy ran the rancho guard and no issues as well
Old Oct 5, 2014 | 08:08 AM
Pylot7's Avatar
I have Rokmen covers on both ends of my 2 door. I have the heavy duty TF front trackbar and a TF 2.5 inch lift on 33 inch tires. No interference issues at all.
And if you saw the marks I put on the covers from a run up a rock garden last week you would appreciate that the stock covers would likely have dented. The only other thing I am wondering about now is the "nose" of the diff as I did bang my rear one pretty good, nothing was damaged but I don't know how much that area of the diff can take.
