Plasti dip removal... help!
Old Oct 4, 2014 | 09:00 AM
Greep's Avatar
Default Plasti dip removal... help!
Dipped my wheels a little over 2 years ago. Love the look. I'm peeling the dip off to either paint or powder coat them. Problem is that it's been on there so long, it's pretty brittle. I put 4 coats on, but it's peeling off in small pieces, and there's a lot that will be ridiculous to get off. Is there something I can spray on there to help this process?
Old Oct 4, 2014 | 09:04 AM
jrod250's Avatar
I had the same issue. I found that reapplying a few coats made it peel off like it was fresh.
If you don't want to do that, WD40 will eat it off, but it makes a mess.
Old Oct 4, 2014 | 09:29 AM
Greep's Avatar
It's already a mess! I'll try anything ;-). Thanks!
Old Oct 4, 2014 | 09:59 AM
jrod250's Avatar
Gasoline will eat it away too, but I wouldn't recommend that
Old Oct 5, 2014 | 03:58 AM
AngryRedBird's Avatar
(plasti-dip)
One my get away with using easy off oven cleaner.. I found while repaintings a few items.. and I made a mistake or the paint run.. I'd use the easy off oven cleaner there after. Although I've never tried to use this in conjunction with any plasti-dip or even on the rims.. I would try on a nondescript area of the rim first..
I guess there is a lesson here somewhere.. thus I'll never use Plasi-dip on any of my stuff. I've seen what happen to good stuff over time..
Old Oct 5, 2014 | 04:54 AM
lulu2533's Avatar
Let us know what worked...I'm thinking about taking the pdip off my stockers before I sell them.
Thanks!!
Old Oct 5, 2014 | 05:06 AM
williamsc75's Avatar
I feel your pain. I'll never use that plasti-dip shit ever again! The wd-40 works or try goof off adhesive remover.
Old Oct 5, 2014 | 06:06 AM
Greep's Avatar
I'm going to soak the remaining areas in WD-40 and use an abrasive plastic sponge. Plasti dip is good for what it does, but the videos made it look like a 5 year old could pull it off in one sheet! Once I get this off, I'll either bed line them or have them powder coated... But no more Plasti dip! I'll keep you posted...
Old Oct 5, 2014 | 06:08 AM
TreyJK's Avatar
A power washer makes it a simple job if you have access to one
Old Oct 5, 2014 | 08:04 AM
stagedtrip's Avatar
My daughter sprayed smiley faces on the shop door, I didn't notice for a week or so, it wouldn't peel and it's not a smooth surface tried picking at it for a bit. Grabbed a rag, dumped some gas on it and the plasti dip wiped right off.
