Teraflex leveling kit sway bar link help
Old Oct 25, 2014 | 01:31 PM
mwtrent's Avatar
Default Teraflex leveling kit sway bar link help
I'm installing the teraflex leveling kit today; the spacer type, and the drivers side went on without a hitch but when I went to tighten the upper sway bar link on the passenger side it just spins and unlike the OE link there isn't a secondary point to put a wrench on. Anyone have any ideas for tightening this nylock?
I don't own an impact wrench.
Thanks in advance...
Old Oct 25, 2014 | 01:41 PM
Kojack's Avatar
Weird, mine have a place to put a wrench, yours should too!
Old Oct 25, 2014 | 01:48 PM
jadmt's Avatar
JK-Forum Ambassador
you sure it does not use a hex wrench in the end of the bolt? put the nut on then hold the bolt from turning using the hex/allen wrench
Old Oct 25, 2014 | 02:52 PM
mwtrent's Avatar
Crap! I didin't even think to check for that. Problem solved. Thanks; let my frustration lead to oversight.
Old Oct 26, 2014 | 01:36 PM
mwtrent's Avatar
Upper sway bar links had an hex key as pointed out. Kit is installed. Thanks again.
