JKS track bar and PSC diff cover......
Old Oct 29, 2014 | 10:14 AM
mstrofpuppets's Avatar
Default JKS track bar and PSC diff cover......
I have a 2011 JKUR with a RK 2.5" lift installed with both RK f/r track bars and the rear TB bracket on the axle side. I installed Poison Spyder D44 diff covers and the RK TB both front and rear hit the diff covers when off-road and minimal flex. I am running 2" bump stops front and rear. I was told to try the JKS TBs because they have more bend in them. Curious if anyone is running this set up and if you are having issues?? Tried to search but couldn't find anything with these two parts together. Thanks for you time!
2011 JKUR, manual trans and some other stuff.....
Old Oct 29, 2014 | 10:16 AM
mpkelley20's Avatar
Can you post a pic of your setup underneath? Wonder if you have the track bar turned the wrong way??
Old Oct 29, 2014 | 11:14 AM
Joe_B's Avatar
I run F/R poison spyder diff covers with JKS track bars and don't have a problem front or rear.
Old Oct 29, 2014 | 11:55 AM
Good to hear. Yea I'll post up some pics. I have had the TB with the bend pointed up and with it pointed out and still it hits. Let me get the pics posted up.......
Old Oct 29, 2014 | 01:49 PM
Addisonmcelya's Avatar
I have the jks track bar and PSC diff cover and it has rubbed on the diff but i havent had any real problems
ID:	582158   Click image for larger version
Old Oct 29, 2014 | 04:35 PM
orngkrate's Avatar
I run Ruff Stuff HD 3/8" covers front and rear. No fitment issues with either stock and then later JKS adj track bars
Sent from my Nexus 7 using Tapatalk
Old Nov 1, 2014 | 05:29 AM
Here is a pic of how I have the RK track bar.
2011JKUR with stuff.....
Old Nov 1, 2014 | 05:56 AM
Matches's Avatar
My JKS rubbed the PSC front cover. I replaced the bar with a Teraflex and have had no problems since.
Old Nov 1, 2014 | 07:28 AM
^^^^^what lift are you running?
Old Nov 1, 2014 | 01:14 PM
Matches's Avatar
2.5" aev
