2.5" Lift & Stock Rim Question
Does anyone know why you can run stock wheels with the AEV 2.5” lift kit but the Teraflex 2.5” lift kit calls for wheels with a minimum of 4.5” backspacing?
About 5 years ago, I had installed the TF 2.5” BB on my Sahara that had stock wheels. The passenger side swaybar link bolt head rubbed the rim which was grounded down to alleviate the issue.
Since that was necessary, I could understand the requirement for wheels with different backspacing, but back then, the TF kit did not come with a rear track bar bracket at all.
I would’ve thought the new kits that come with a rear trackbar bracket would’ve alleviated the issue and stock wheels would be fine so I’m wondering what the issue is.
Yeah, I'm looking to run my 35" MTRs that are on 15" rims most of the year but I'd like to be able to throw the stockers on during the winter. I really don't want to buy spacers to run the stock setup for a couple months a year.
You can run stock wheels and tires, but if you want to run wider tires your going to need spacers or new rims.
The issue is the rear links on the TF lift and since the AEV 2.5 does not come with rear links.
Here is what happens with longer TF links and 285/70r17 duratracs on 8.5" wheels with 5.2" backspace
Will have some spare Spidertrax spacers going cheap, once my Method wheels arrive.
