Disconnecting with Teraflex BB?
Old Nov 5, 2014 | 07:07 PM
TheNoob's Avatar
Default Disconnecting with Teraflex BB?
Quick question, is it safe to disconnect my front swaybar when running a 2.5" BB with Shock Extensions? I already have the Teraflex quick discos installed too. I was just wondering if I need to do an exhaust spacer for the front driveshaft to clear the exhaust, or am I good to go? Don't want to cause any damage. I'm not going to go through extreme trails any time soon, but when I do hit a trail I'd like to disconnect for a comfy ride and extra articulation. Thanks in advance.
P.S. I was thinking of using my HiLift jack to raise a front corner while the exhaust is cold so that it wont damage the DS boot. Would this be a proper way to check if it'll clear?
Old Nov 5, 2014 | 07:42 PM
kjeeper10's Avatar
Vet Army
Yes, I was going to say flex it out and see what happens.
2007 Rubicon /2 door/6 speed
Old Nov 12, 2014 | 03:59 PM
TheNoob's Avatar
Finally had the time today to flex out the Teraflex BB. Happy to say that the front driveshaft does NOT make contact with the exhaust.
Flexed it with the Hi Lift
Enought to get the wheel off the ground (shock acting as a limiting strap)
Clearance between DS and exhaust (1cm more of travel and it would have touched)
Look of suspension flexed
And suspension from behind
I was going to pick up a set of Rubi shocks off craigslist over the weekend, glad I didn't. From what I've read they extend 1" longer than non-rubicon shocks. For now I can disconnect without fear of driveshaft being damaged from the exhaust
Hopefully this information helps someone.
Old Nov 12, 2014 | 04:06 PM
JTB488's Avatar
Just a FYI..check you brake lines too. I just did the "leveling kit" 2" front 1" rear and when re-installing the springs I had to unbolt the brake line mounts, tight!
Old Nov 12, 2014 | 04:52 PM
TheNoob's Avatar
Yeah I don't know if you can tell from my pics but mine is no longer attached to the brake line. I cut it off with an angle grinder and just put a loose zip-tie around the shock and the lines. There was no way I would have been able to bolt that bracket back on. I wonder if its only on newer jk's as instructions don't mention this piece.
Old Nov 13, 2014 | 07:54 AM
Offroad_Elements's Avatar
Former Vendor
Here was my Jeep a few years back. Had the TF Budget Boost, with the longer travel Bilstein 5100 shocks, coil retainer clips, and bump stopped accordingly. Lots of suspension travel.
Name:	JK on barrier.jpg
Old Nov 13, 2014 | 08:11 AM
TheNoob's Avatar
That is the most flex I've seen with a BB. Impressive. Thanks for sharing!
Old Nov 13, 2014 | 08:14 AM
wittys-jk's Avatar
Ran a budget for a little while with the same set-up with the shock extenders and then I got longer Terraflex shocks and I promptly went through 2 stock shafts from too much flex. Have upgraded to 3" coils and an Adams driveshaft since then so I don't have the flex issues anymore so its good that you are taking the time to check everything.
Here is a pic of the first one I broke back in the day and how I did it.
ID:	584161Click image for larger version
Name:	dsc00581 (800x532).jpg
ID:	584157   Click image for larger version
ID:	584158   Click image for larger version
