what is this?
Old Nov 15, 2014 | 02:02 PM
Jp3792's Avatar
Default what is this?
So i have a 2008 rubicon and noticed this wire was busted.. and no to sure what it is? Locker?
Old Nov 15, 2014 | 02:24 PM
D_engel's Avatar
locker. Should be plugged into the connector at the top of the pumpkin, just to the right of the control arm in the picture.
Old Nov 15, 2014 | 02:43 PM
Jp3792's Avatar
Yeah its broke guess i have to fix it.
Old Nov 15, 2014 | 03:34 PM
Jp3792's Avatar
Is their a part number for it? The wiring is fine but the plastic piece is hopped
Old Nov 16, 2014 | 05:14 AM
cormac827's Avatar
You could just tie the wires together. Not sure on part number.
Old Nov 16, 2014 | 11:33 AM
pickjones's Avatar
Lookup all your connector part numbers here
http://connectors.dcctools.com/home.htm
Old Nov 17, 2014 | 04:13 PM
Smashboogie 4x4's Avatar
Former Vendor
It's not the connector that is broken it is the locker actuator that is broken. If you go to your local dealer you should be able to pick it up for about $20 or so. You will need to unbolt it from the housing and install the new actuator. You will also need to pick out the rest of it from the connector on the end of the wire.
Here is the part number for what you need: 68003570AA
Old Jan 16, 2015 | 06:33 PM
Jp3792's Avatar
Okay will do. Thank you.
