Rims and tire question, need advise
Old Nov 16, 2014 | 12:20 PM
machoramcharger's Avatar
Default Rims and tire question, need advise
Getting ready to purchase some tires and maybe some rims for my 2011 jeep jk and it has the factory rims on it right now 255/75/17 and It also has a 2.5 RC lift on it currently. I want to upgrade to the bfg km2 and something bigger then what I have on it right now, maybe a 33". I also like the looks of the black steel cragar soft 8 rims but it doesn't look like they make the correct size rims for it. I looks like they have a 17" rim that 9.5 inches wide which is to wide. Can any one point me in the right direction. Click image for larger version
Old Nov 16, 2014 | 12:29 PM
bludevlsi's Avatar
Summit racing has 17X8. 4.5 backspace. $92 each
Old Nov 16, 2014 | 12:56 PM
Cool thanks just what I needed to know. 17x8 cragar soft 8's are what I wanted I'll give them a call and order up five with that back spacing. Any one know if these rims will rub at all with out spacers?
Thanks !
Here's a picture of the look I'm going for. I think the one in this picture has 35's on it though.Click image for larger version
Old Nov 16, 2014 | 01:12 PM
I really wouldn't mind installing a 4" lift and 35 km2's but the jeep is already doggy as it is and I know adding the 35's wouldn't help.
Old Nov 16, 2014 | 01:26 PM
nthinuf's Avatar
That's why there are thousands of "what gears should I go with" threads to read through. Expensive, but worth it to bring the rpm/hp/torque back up to a more usable level.
Old Nov 16, 2014 | 06:05 PM
bludevlsi's Avatar
Also dont need anywhere near a 4"lift to fit 35's. 2.5 is all you need.
Old Nov 25, 2014 | 03:17 PM
tires are all installed, the rims are a little different then what I wanted but I kind of like them flush with the out side of the tires. What are your thoughts on the rims. Click image for larger version
Old Nov 25, 2014 | 03:22 PM
nthinuf's Avatar
Cloudy day, black rims next to black tires next to black flares/bumpers/steps next to black paint. What kind of comments were you looking for? It's all black. But hey, at least I can tell that you have rims in there...
Old Dec 22, 2014 | 05:20 AM
What's my easiest way of adding another inch higher on stance? I think it would look better just a hair higher? would a 1" body lift work?
Old Dec 22, 2014 | 06:25 PM
CerOf's Avatar
I'd go with a Teraflex leveling kit. Lifts the front 2" and rear 1" with spacers above the coil springs.
Sent from some string and a few tin cans.
