Tq/bump stear trouble shooting after rk 2.5 x and artec install.
I have rubicon Jku 2013 with 35s. I had the RK flex kit and resently upgrades to the 2.5 flex kit and at same time I had ARtec truss and ball joints installed. 35s are BFG aT at 28lbs.
When I accelerate the wheel pulls to left let off gas at high speed and goes to right. Dips in road do same thing.
Had front end alignment done and they got me ar 1/8 toe and 4 3/4 caster. They had to center axel a bit as well. I didn't have rear checked. My installer said it doesn't matter if u tighten the arms on the ground or on lift. He tightned on lift.
I am going to trouble shoot this weekend and was looking for help. I was woundering if maybe it's my thrust angle, ball joints need to losen up, rear axel not centered or if I should losen all arms jump on bumper and retighten. So I was going to do the following
1. Check rear axel center.
2. Check rear toe.
3. Losen the arm bolts. Jump on bumpers and tq to spec
Any other ideas? Thanks in advance.
2. Check rear toe.
do you have raised trackbar mounts front or rear? Still running the stock draglink?
Your installer was wrong about torquing the arms on the lift. It should always be done at ride height to prevent premature bushing wear and ensure a more comfortable ride
Okay. Can the bolting on ground cause stearing issues? The track bar is bolted to the artec truss. Shocks are fox for lift. Few pics. I don't know if tb mount is in stock location or not. The empty bolt is for my fix ATS.
Like previously mentioned, tightening things up on the lift is horribly wrong. I actually drive the jeep for around the yard so everything settles, then park on a flat surface and finishing torquing to manufacturers specs. Make good and sure that you check every single bolt and nut. That is likely the problem.
From the above picture, it looks like your draglink is lower than your TB at the Axle/knuckle side. You want the draglink and TB to be as parallel as possible to fix the bump steer. You may require a trackbar flip to fix it. I have the artec truss, synergy TB bracket and DL flip kit installed on mine and i also have the RK 2.5 X-Factor. No clearance issues at full flex with 33" tires.
That is a raised trackbar bracket in the pic, correct? As noted, raising the axle end of the trackbar without also flipping the axle end of the draglink (up on top of the knuckle) is the cause of your new bumpsteer. Draglink flips generally require a minimum of 3" extended bumpstops to keep the draglink from contacting the frame.
Do some measuring to see if you can make it work, or consider removing the bracket...
Thanks for all the info. The track bar bracket is part of the artec truss system and it has 3 mounting locations. It is welded in as part of the truss. Let me get some better pics up this evening or tommorow to help with u guys seeing stearing angles and the bracker. I think there be a bit of an optical issues ion from my pic.
