JK 6sp to auto swap. Wiring?
Old Jan 20, 2015 | 04:44 AM
lurch12pumper's Avatar
Default JK 6sp to auto swap. Wiring?
gotta 08 JK with 6sp. im having ATS build an automatic for it. has anyone done a swap like this. i did a auto to NV4500 in my 12v. i was just wondering about the wiring and computer issues. i got big plans on this build. 5.5" Rock Krawler lift. Currie Dana 60s on 40s. Front/rear air lockers. hydraulic steering. cage. just to name a few. any help is greatly appreciated
Old Jan 20, 2015 | 05:43 AM
Invest2m4's Avatar
This will be interesting. I've seen a few people swap in a stock JK auto trans. It was quite the mess. Took a few months messing with the computer and eventually it worked. Swapping in a none JK trans? I can't see how that would ever be able to work with the JK computer. Those that swap to the stock auto have the computer flashed to an auto, but that is not an option for you (unless they are building a beefed up JK Auto with the same gear ratios). Best bet is to junk the electronics.
Old Jan 20, 2015 | 01:29 PM
thanks invest2m4. its a stock auto just built by ATS. we are a diesel shop and did a favor for them so they are returning the favor. you reckon a junk yard harness and computer will do? if reflash dont work
Old Jan 20, 2015 | 01:34 PM
Invest2m4's Avatar
Here's a good thread on it to read. I think it will give you the info you need or lead you to a place or person who can. I think somewhere in it is even a list of all the parts you need. It's a lot...
http://www.jkowners.com/forum/showth...nual+auto+swap
Old Jan 20, 2015 | 01:49 PM
thanks again. ill find my way around this forum soon enough. especially as this JK build goes on.
