Rock jock 60 and rock krawler lift
Have a 3.5" inch wheel base streched 3 link lift from rock Krawler. I am going to replace the rear Dana 44 with a larger axle. The threes link has different brackets than the stock axle. Does anyone make a kit to make these components work together? Has anyone already done this? Any help is appreciated.
Just buy brackets from someone like Artec. They have what you need.
Keep in mind, that you are likely going to change the geometry of the suspension due to change in separation of the links at the axle. You'll want to try and maintain the same vertical distance. The other issue you will need to check is that the upper link has clearance. That's a much larger axle and you don't want a link going through the floor.
Basically, you need a truss, upper link, and lower links. Examples below. Just call Artec and tell them what axle and what you need. They are familiar with the RK kit.
Artec Industries 14 bolt MODULAR Axle truss
Artec Industries Truss Upper Link Mounts
Artec Industries Lower Link Axle Brackets
