ome
Old Mar 9, 2008 | 10:19 AM
zeeksta's Avatar
Default ome
what are ome guys using for bumpstops?
Old Mar 9, 2008 | 02:10 PM
nukeman's Avatar
I used bumpstops from a TF BB kit. They work perfectly, but it also depends on what size tires and wheels you are using. I run 35's with a 17 x 8, 4.5BS wheel. You can buy bumpstops from just about any online vendor, and Teraflex will sell you theirs if you call them direct.
Old Mar 9, 2008 | 03:05 PM
zeeksta's Avatar
i have a set, i guess i shouldve left them in!!!!
Old Mar 9, 2008 | 07:13 PM
swampdonkey's Avatar
Stock bumpstops
Old Mar 9, 2008 | 09:36 PM
nukeman's Avatar
Originally Posted by swampdonkey
Stock bumpstops
I wouldn't recommend this if you are going to run 35" tires, especially not if you plan on disconnecting your front swaybar.
Old Mar 9, 2008 | 10:18 PM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Call me silly, but I'm not using anything. I assume that you don't need them and if you did they would have included them in the kit.
Old Mar 10, 2008 | 04:23 AM
Robar's Avatar
Old Mar 10, 2008 | 09:16 AM
zeeksta's Avatar
im waiting to get body lift in to see if need anything.
i took out the tf ones because the ome didnt come with any, so i figured ill go stock
Old Mar 10, 2008 | 10:48 AM
steelblueJK's Avatar
Same with me If one uses bumpstops because of to big wheels, the lift is not enough ......
Old Mar 10, 2008 | 11:42 AM
hiteck's Avatar
I thought the whole purpose of the bump stops was to one keep the shock from topping out when the axle comes up as the other side droops?
