ome
Old Mar 10, 2008 | 11:45 AM
swampdonkey's Avatar
I have been told the stock bumpstops are fine with the OME. *Note I'm using the OME shocks that came with the kit. If you're not using the OME shocks, then that could be a different story.
Old Mar 10, 2008 | 01:26 PM
steelblueJK's Avatar
Originally Posted by hiteck
I thought the whole purpose of the bump stops was to one keep the shock from topping out when the axle comes up as the other side droops?
Exact ... and the OME does not need them, the shocks are short enough. Only in case of the rear relo bracket you´ll need them in the rear.
But if you have too big tires, you maybe could use them to eleminate rubbing
Old Mar 10, 2008 | 02:21 PM
zeeksta's Avatar
i have the ome shocks front and rear.
if you have the stock bumpstops i would think almost any large tire would hit, wouldnt they? that puts the centerline of the axle in the same spot as the stock spring.
