Heated seat install question
Old Feb 18, 2015 | 04:12 AM
Pyro1415's Avatar
Default Heated seat install question
Hey guys I thought I read somewhere that heated seats could be installed without removing the seats. A few people have told me you have to and I can no longer find a write up where someone didn't. Any help on if this is easily done is appreciated. 2010jku auto.
Old Feb 18, 2015 | 05:05 AM
uf126's Avatar
I installed them without taking the seats out. Mainly because I couldn't get the bolts undone and didn't have the patience to PB blast them.
I did a basic overview of the steps in the below thread. No pics but do a search as I thought I had used someone else's write up as a guideline when I did my install.
https://www.jk-forum.com/forums/modi...-seats-315506/
Old Feb 18, 2015 | 10:14 AM
tcdawg's Avatar
You don't have to pull the seats but it makes life a lot easier, especially if you are putting your switches in the center console.
Pulling the seats is pretty darn easy. Takes 10 minutes a seat, max
Old Feb 18, 2015 | 11:46 AM
JAM85's Avatar
Left my seats in. It can be done.
Old Feb 18, 2015 | 07:34 PM
Pyro1415's Avatar
Thanks gents I try not to mess with seats for the safety aspect. I don't have a torque wrench and don't want to go with eh tight enough. I'll search for the thread again. Plus I have to do this at my work and that would be awkward if the boss came in and I had my seats on a table.
Old Feb 19, 2015 | 03:59 AM
Pyro1415's Avatar
Did you still disconnect the battery?
Old Feb 19, 2015 | 07:13 AM
uf126's Avatar
I would recommend doing it because you're messing around where the side airbag connections are underneath the seats. Best to disconnect the battery in my opinion.
Old Feb 19, 2015 | 07:41 AM
Pyro1415's Avatar
I don't have side airbags. That's why I was wondering.
Old Feb 21, 2015 | 07:32 PM
69mach1's Avatar
Cool
Checking what seat heaters you went with? I must admit they spoil me in our TDI and I'd like to put them in my JKU, at least in the front seat ;-)
Was it a pain in the ass or easy job?
Old Feb 21, 2015 | 08:33 PM
Jake7978's Avatar
Did mine in my 10 a while back. Used the Dorman heated seat kit from Amazon....works great. Easiest way to do it is remove the seat to install the pads...otherwise pretty self explanatory
