Mopar tranny coolet
Old Feb 26, 2015 | 01:32 PM
bluebear's Avatar
Wife picked up a cooler (3.8L) for me as a gift and I'm not going to complain. I know there are way cheaper alternatives. Anyways, the install instructions are worthless...drawings without written instructions. I know it's not rocket science but does anyone know if an instructional install video or write up for this particular cooler exists? I've searched and cant find one. Pardon the typo...cooler (fat thumbs) and I can't edit the title.
Old Feb 26, 2015 | 02:44 PM
azxr's Avatar
Default Write Up
There are several in the write up section.
https://www.jk-forum.com/forums/jk-w...-cooler-37839/
search the write up section for transmission cooler.
blue project's Avatar
Are you referring to the oem cooler they claim is for towing? I believe it's the same one that comes in the 2012's and up. That's what i did and while mostly useless it not that difficult. The hardest part is removing the transmission lines to swap in the new piece. There's a special tool for that. Also there is a plastic dam or something that comes out as well. Removing the grill and bumper are a must.
Old Feb 26, 2015 | 02:57 PM
ronjenx's Avatar
Bumper removal is not required.
Old Feb 26, 2015 | 03:05 PM
Old Feb 26, 2015 | 07:01 PM
bluebear's Avatar
Angry
Looking for an install write up SPECIFICALLY for the Mopar cooler. That thread mentions the unit but has a lot of tips for the BME cooler. Thanks anyways.
Not sure what 2012s are equipped with but mine is part number 82212486AB
Directions are clear as mud
Old Feb 26, 2015 | 07:05 PM
ronjenx's Avatar
The 2012+ JKs have a cooler similar to the OEM kit you are referring to. The plumbing is a little different.
I have not seen a write-up for the kit. I have installed 3 of them, so if you have questions, feel free to ask.
Old Feb 26, 2015 | 08:25 PM
SoK66's Avatar
It's a very straight forward install. Highly advantageous to get the recommended jiffy Tite 3/8" quick release tool for the cooler lines. You can release them with a small pick tool, but the Jiffy Tite tool makes it very easy. Mounting it is a snap. You need some sharp shears to trim the lower cooler shroud.
Old Feb 27, 2015 | 03:32 AM
bluebear's Avatar
Originally Posted by ronjenx
The 2012+ JKs have a cooler similar to the OEM kit you are referring to. The plumbing is a little different. I have not seen a write-up for the kit. I have installed 3 of them, so if you have questions, feel free to ask.
Thanks...let me start with something simple that the directions don't even state...how much fluid will I need to add?
Old Feb 27, 2015 | 05:56 AM
ronjenx's Avatar
I didn't lose enough fluid to have to add any. Others have lost some. I don't recall how much, but having a quart on hand should be enough. If you see fluid pouring out of the disconnected line, raise it as high as you can until you're ready to reconnect it.
