advice on RIPP SC
Old Mar 4, 2015 | 11:19 AM
LockEmUp-47's Avatar
Default advice on RIPP SC
I have an opportunity to purchase a new/unused (still in the box) RIPP Gen2 Supercharger Kit Si-Trim Stage 2 with intercooler for $3,500. The kit was originally purchased from RIPP in July 2012 but never installed or used.
When I contacted RIPP to see if any changes have been made since that model was sold at that time, Chris from RIPP advised that they "made some changes around that time in regards to pipes and mounting locations" and that it may cost me an additional $1700 to upgrade the kit to current standards so that it operates and functions properly, but that he couldn't be sure unless he sees the actual parts.
Will I be screwed if I purchase this and it needs to be upgraded, because I can't afford another $1700 ??
Will this unit not work right without being upgraded??
Old Mar 4, 2015 | 11:35 AM
mhockey9090's Avatar
Vet Army
You just answered your own question right here.
Old Mar 4, 2015 | 11:49 AM
I was hoping someone would chime in with direct knowledge on the RIPP supercharger kits and maybe be able to advise whether or not it is necessary to have this upgrade, or if the kit will still perform as advertised without upgrading
Old Mar 4, 2015 | 01:58 PM
Tripletsi's Avatar
Compare the pictures on the RIPP website, just an idea.
Old Mar 4, 2015 | 02:50 PM
MTNBKR's Avatar
I run the same style of RIPP you have installed in a 2008 Wrangler JKU. What you need to determine is if the RIPP SC your looking at will work in the Jeep you have. if you have a 2012 or newer, there may actually be some minor changes such as: Brackets, the Tune in the supplied Diablo Tuner, and the injectors may be different. They definitely are different from the one I have. Do your research and you'll be fine. Call 4WD or some other cpmpanies that seel the RIPP SC's to get a better picture. I can't imagine there is a $1700.00 change however.
Good luck
Mtnbkr
Old Mar 4, 2015 | 06:15 PM
I don't have the supercharger in hand because I haven't paid for it, so it hasn't been shipped to me. But it was originally purchased for a 2010 3.8 wrangler with manual transmission, and I have a 2009 3.8 wrangler with 6spd manual. my concern is that RIPP said that even though it should theoretically work on my application, they made changes sometime around the time that this particular SC was purchased, and those changes could cost me an additional $1700 to update to current specs.
i'm trying to figure out if this will still work without upgrading the parts or if those upgrades are critical and/or necessary
Old Mar 4, 2015 | 06:27 PM
MTNBKR's Avatar
I don't have the supercharger in hand because I haven't paid for it, so it hasn't been shipped to me. But it was originally purchased for a 2010 3.8 wrangler with manual transmission, and I have a 2009 3.8 wrangler with 6spd manual. my concern is that RIPP said that even though it should theoretically work on my application, they made changes sometime around the time that this particular SC was purchased, and those changes could cost me an additional $1700 to update to current specs. i'm trying to figure out if this will still work without upgrading the parts or if those upgrades are critical and/or necessary
Let me see what i can find
Old Mar 4, 2015 | 07:58 PM
PARTS INCLUDED:
2011 JK PIP5 FUEL PIPE/INJ
2007-2011 JK 3.8 SRP BELT
2007-2011 JK 3.8 FMIC CLAMP KIT
2007-2011 HARDWARE PACK
2007-2011 2.5" 90* PIPE 2
2007-2011 JK 3.8 INDUCTION PIPE CUSTOM
RIPP 30PSI PCV VALVE
VORTECH V3SI TRIM S/C 0 TILT SATIN
UNIVERSAL SDS STAINLESS IDLER 00013 (QTY 2)
PROMO PACK ALL
2.75 45 DEGREE BLACK
2.5" 2.5" BLACK REDUCER
FCM-FUEL CONTROL MODULE VR_27
T-BOLT CLAMP 3.75"
VORTECH 3PK V3 OIL
2007-2011 JK3.8 NGK 1 STEP PLUG SINGLE (QTY 6)
2007-2011 JK BRACKET ASSY PWD COAT
2007-2011 JK3.8 INTERCOOLER
2007-2011 2.5" 90* PIPE 1
2007-2011 2.5" 90* PIPE 3
2007-2011 JK3.8 VAC PACK
2007-2011 JK FCM HARNESS
RIPP SDS AIR FILTER CHROME OR BLACK
RIPP SDS PULLEY 00015
2.5 STRAIGHT BLK COUPLER (QTY 3)
VORTECH 3PK V3 OIL
2.75 TO 2.5 BLACK 90 DEGREE REDUCER
MAP SENSOR 2.5 BLUE
BLACK BYPASS VALVE
DiabloSport Predator tuner and software
Old Mar 4, 2015 | 08:19 PM
haydhess's Avatar
I run a Ripp SC on my 09 and That parts list looks pretty complete to me. The only thing I didn't see (maybe I missed them) is the aftermarket fuel injectors for the kit. Overall though it seems like what you need is there. I don't know what changes ripp made for these kits after they started putting out their kits for the 3.6 though...
Old Mar 4, 2015 | 08:22 PM
nthinuf's Avatar
Seems to me that another call to Ripp is in order. They said that you may need parts to upgrade it to the "current version", right? So ask them what the problem was with the old version. (since people were already using it, maybe it wasn't a big deal?).
