Synergy draglink not flipped
I I added the synergy draglink. I am flipping it but not yet.
I also have the synergy tie Rod. The grease fitting from the draglink is just barely clearing the TRE. To the point that after my first drive it was gone... I hope the threaded end is not inside the draglink end now. If it is is that something to be concerned about? I'm thinking the fitting material is no match for the joint, and it will just get mashed up if it is in there.
I switched to a lower profile fitting and it seems ok. I going to put on a slimmer one tomorrow, the one that requires a needle adapter.
Sent from my LG-LS980 using JK-Forum
Little heavy on the grease! Lol
Are your pitman arm threads extended out that much also?
If not, I'd split the difference between pitman and knuckle sides.
That looks like too much wound out on those man.
^^Yeah, it shouldn't exceed 3.5" from center of tie rod end to the crush nut.
Pretty sure it is a synergy Rod. Came with the axle when I bought it and I could have sworn that what it was.
I have less than 3" of threads out. The instructions called for no more than 3.5".
I will be flipping it in a 1-2 weeks so they will get wound back in then also...
No ideas on the clearance issue?
