Problems wiring winch
Old Mar 30, 2015 | 08:57 AM
JeepAngus's Avatar
Default Problems wiring winch
I installed by Smittybuilt XRC 9.5 Gen2 winch. I wanted a cutoff switch so I used this one:
Battery DoctorŽ Rotary Dial Disconnect Switches - Wirthco Engineering, Inc.
I purchased it from Amazon. I ran the neg from the winch to the switch, and a short cable from the switch to the battery. And the winch works regardless of the switch position. I emailed Wirthco and they give the same instructions. So is the winch otherwise grounded? Should I put the switch on the hot side? Thanks
Old Mar 30, 2015 | 09:04 AM
MikeRM's Avatar
The winch is going to ground itself to the mount and frame. The switch will need to be on the positive side.
Old Mar 30, 2015 | 07:39 PM
TheNoob's Avatar
+1 switch goes on the positive side
Old Mar 31, 2015 | 02:58 AM
JeepAngus's Avatar
Done. You were right. Winch was grounding itself. I put the switch on the positive side and it works like a charm. Thanks
