Delaware Mechanic Needed to Regear 2014 JK.
Old Apr 6, 2015 | 12:30 PM
Unforgivable's Avatar
Default Delaware Mechanic Needed to Regear 2014 JK.
Im from Middletown DE. Looking to upgrade gear ratios to 4.88's sometime soon. Need someone in the area.
Old Apr 18, 2015 | 06:57 PM
crcjk's Avatar
It is kind of a drive for you, but Call Lindale at 4x4 Suspension and Gear in Lansdale, PA. This guy really knows gears and axles, and did a great job on two rigs for me and a friend.
Old Apr 21, 2015 | 06:00 AM
I used them before. I found someone local. Thank you.
Old May 19, 2015 | 12:41 PM
Whiz Wit's Avatar
Hey could you tell me who you ended up going with and if you were happy with the results? Also, which gearing did you go with and how much was it?
Thanks!
Rob
Old May 19, 2015 | 12:58 PM
ACJK22's Avatar
If you end up still needing someone, check out the JP Shop in Chester Springs. They are great guys and did an awesome job on my rig
The Jp Shop
Old May 20, 2015 | 01:32 PM
Whiz Wit's Avatar
Thanks but looks like it's about an hour away. Looking for something a little closer. However I'll definitely keep them in mind. Thanks again!
