Upgrade a 2.5 teraflex bb with shocks
Old Apr 9, 2015 | 03:56 PM
ericgoogs's Avatar
Default Upgrade a 2.5 teraflex bb with shocks
Currently have a 2.5 Teraflex budget boost w/ Teraflex vss shocks, running 35" pro comp MT, flat fenders, teraflex monster HD adjustable track bar, AEV geo correction bracket, bilstein steering stabilizer.
What would it take for me to go slightly higher to be able to add a heavier bumper and eliminate the budget boost spacers? Would I be able to get the 3" Teraflex springs for the front only and replace the stock springs and spacers from the budget boost and be set? Or would I need other parts also, such as new sway bar links and parts for the rear?
Thanks.
Old Apr 9, 2015 | 06:04 PM
blowermax's Avatar
I have a 3.5 lift with 35's....the kit comes with front swaybar links....you use the oe links and put them in the rear....there is a tracbar bracket for the rear...i would get an adj front trac bar...dont think you need anything else....
Old Apr 9, 2015 | 06:14 PM
ericgoogs's Avatar
I have an adjustable monster forged HD from Teraflex already as I stated. I also already run the 2.5 BB with 35" tires. I just need to know if I would be able to switch out the from OE springs and spacers from the bb, with the Teraflex 3 inch springs, there for keeping my lift, and compensating for the bumpers I am about to add. Would the front springs be okay to add on there own? Or would I need to change out more than just this?
Old Apr 9, 2015 | 06:26 PM
blowermax's Avatar
I dont have the exact setup up but my front dropped maybe 1/2 inch with the front bumper and winch...this is on a 3.5 lift tho...so it should bring you back down to 2.5/2.75...you might have to change the swaybar links but thats about it IMO
