Lift question
Old Jun 2, 2015 | 11:31 AM
JK1124's Avatar
Default Lift question
My buddy has a 2014 Unlimited Rubicon X and had the dealer put on a Mopar lift. He gave me his complete stock suspension. I am looking at a 2015 2door sport to wrench on, will the 2014 rubicon 4-door suspension parts work on a 2-door? I didn't know if the different spring ratings on a 4 door would make a difference. Any answers would be greatly appreciated.
Old Jun 2, 2015 | 11:33 AM
JKingAround's Avatar
If it is a hard top you should get a good 2 inches putting it on a 2 door.
Old Jun 2, 2015 | 11:36 AM
jadmt's Avatar
JK-Forum Ambassador
the coils have tags with numbers followed by 2 letters what are the numbers? what are the numbers on yours? technically it is possible that they are identical to yours altho unlikely.
JK1124's Avatar
His was a rubicon unl x hard top, the sport I have my eye on is soft, no ac, stick, no power anything
Old Jun 2, 2015 | 12:46 PM
Cutman's Avatar
Depending on where you live, I'd rethink the AC. When it's raining in summer and it's 90° and humid....worth the $1200 imo. I didn't use mine last year until August. When the temp is over 100. I'm not ashamed.
Old Jun 2, 2015 | 12:57 PM
pbujku13's Avatar
^ get the AC. My TJ was murder in 100s and 0 MPH.
Old Jun 2, 2015 | 01:01 PM
JK505's Avatar
I'll be the outcast... I have AC but I have only used it twice. As a disclaimer I run no doors if it's 32 degrees or higher, rain or shine. In the rain I have the soft top up, and side windows in but that's it. It's actually not bad without AC. The VA Humidity will kill you though and at a stand still it's miserable.
I have the X (old sport essentially) with AC, no power anything, and Cruise control. Ripped the carpet out and bed lined it and I don't care what the weather says, no doors!!!
Old Jun 2, 2015 | 11:22 PM
JK1124's Avatar
ID:	613440Click image for larger version
ID:	613441Click image for larger version
ID:	613442 @jadmt he also gave me control arms and bump stops, but i'm pretty sure those are standard throughout the modelsClick image for larger version
somehow this thread ended up being about an a/c i know i don't want since this is gonna be a weekend warrior, i have a RAM 1500 for when its 100 degrees; will these parts work?
Old Jun 3, 2015 | 03:05 AM
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by JK1124
Attachment 613440Attachment 613441Attachment 613442 @jadmt he also gave me control arms and bump stops, but i'm pretty sure those are standard throughout the modelsAttachment 613440Attachment 613441Attachment 613442
those will give you some lift depending on your spring numbers. 60 rears are about tops and 18's are too, 19 is the most in the front for non 10A/X jeeps. rubi shocks are an upgrade over sports and you are correct the control arms are the same.
