after lift, steering issue
Old Jun 18, 2015 | 06:36 AM
Sweat's Avatar
Default after lift, steering issue
Guys, needing some help here. I have a 2012 JK unlimited and just installed a 3.5'' rough country lift and 35'' tires. Also took it and had an allignment done. For some reason when I turn to the left it's fine but when I turn to the right, the steering wheel will go almost 1/4 of a full rotation before the tires respond. It is dangerous to drive like this but I can't get it to do it while in the drive way. Have any of you ran into this problem before?
Old Jun 18, 2015 | 09:09 AM
D_engel's Avatar
Have you had any wobble while driving? Any sort of strange metallic clanking?
Old Jun 18, 2015 | 12:28 PM
Sweat's Avatar
Nothing like that. It drives and sounds fine besides the turning right issue. Sometimes when it does it, it will turn the traction control on too. It's like something is trying to give and allows it to turn before it finally catches
Old Jun 18, 2015 | 12:32 PM
blockrockin's Avatar
i would have someone turn the wheel back and forth while you take a close look at the front end parts and look for any issues , sounds like something is loose/ broken ..goodluck
Old Jun 18, 2015 | 05:57 PM
Sahara Lee's Avatar
As blockrockin said...
Go through PlanMan's suspension check to diagnose where your problem is. More than likely, something is loose.
https://www.jk-forum.com/forums/jk-w...obbles-260145/
Old Jun 19, 2015 | 11:03 PM
jonnysjk's Avatar
This is the same sort of issue I am having but it has been both directions. I have checked over everything but am looking at getting a draglink flip kit and reinstalling the factory pitman arm
Old Jun 20, 2015 | 05:57 AM
TheDirtman's Avatar
That is a terrible kit as far as the way it addresses steering geometry. I would start by going over all the bolts in the linkages (drag link and track bar) as well as the drop bracket and make sure they are torqued correctly. Check the pitman arm to make sure it is not slipping. Have someone turn the wheel while you look over everything. The steering box may also have been damaged when the drop pitman arm was installed.
Old Jun 22, 2015 | 05:48 PM
Sahara Lee's Avatar
I have a drop pitman arm that works good for me. One thing I did notice was a LOT of play in the steering box after installing it. I only torqued it to about 150 ftlbs because I didn't have a proper hold back. After getting a 4' long 2" pipe over the arm end ad a hold back I was able to torque it to 185 ftlbs (factory spec) and all the steering box play went away.
Old Jun 22, 2015 | 06:03 PM
A.W.D.eLussey's Avatar
I had this issue after my lift. Even after taking it in to my installing mechanic. It started with the steering taking a quartet turn in one direction and the occasional ESP light. My trackbar was not torqued enough. It would move a bit back and forth. Basically it took a quarter turn to catch. Start there. Make sure it's torqued to spec and not any less. Good luck.
