Another noise while turning steering wheel
Old Aug 13, 2015 | 01:44 PM
mountainbikeguy's Avatar
Default Another noise while turning steering wheel
I've done some research on this issue, but still need some help.
At a stop or near stop, when I turn the steering wheel lock to lock, I hear a th-thump. It's not a pop or a thump, it's a th-thump (kind of like a heart beat). From steering wheel centered to left or right lock, there are a total of two th-thumps. No difference in feel on left or right turn. Previous threads have pointed to the U joints or linkage arms.
Any thoughts on this being the U joints, linkage arms, or some other issue?
Old Aug 13, 2015 | 02:35 PM
Grimmjpr's Avatar
I'm going to go with loose or wallowed track bar bolt/hole/mount.....I have heard a loose track bar bolt make a snapping sound to a pop, and a dull thud as well.....hope you find out what it is and get it quieted down.
Old Aug 13, 2015 | 02:37 PM
headrock's Avatar
Definitely check those trac bar bolts and get them to 125 ft lbs
Old Aug 13, 2015 | 03:11 PM
Thanks. I'll take a look.
Old Aug 13, 2015 | 03:12 PM
I'll check torque and report back.
Old Aug 14, 2015 | 10:32 AM
Torque wrench set at 120. Bolts are tight. What else could it be?
Old Aug 14, 2015 | 11:25 AM
Monte417's Avatar
It's probably your intermediate shaft. Some grease in the boot should fix your issue
