Rubicon Express 5.5 inch long arm
Is anyone running this kit? How do you like it and have you had any problems??
I just put one on my 2015 4 door Hard Rock edition
I'm running super swamper m16 37x13.5x17 for now but going to change to
toyo mt in the same size
i had it in to 4 wheel parts and they set up the front end but the steering just doesn't feel right
any feedback??
thanks
any feedback??
thanks
fox 2.0 remote res shocks
fox steering damper
30 psi
4.4 degrees positive caster
almost feels like a lot of bump steer
just a lot of feed back in the steering
Reduce your tire pressure to 25 ish. Make sure your steering stabilizer doesn't have any dead spots. Check your ball joints. I ended up replacing mine all the bump steer problems are gone.
Is your drag link flipped? With that much lift, you will have a ton of bump steer given the angle on the drag link and track bar. Really, anything over 3.5" requires a drag link flip and track bar relocation.
Yes drag link is flipped as well as drop bracket and adjustable track bar
I'll try the tire psi and see how that works
thank you
