Bedtred Installation on 2-Door 2015 JK
Old Aug 30, 2015 | 02:53 PM
sbxjunkie's Avatar
Default Bedtred Installation on 2-Door 2015 JK
To the ones who had installed this, what did you do with the rear seat belts? Do I need to cut holes to fit the seat belts? Or should I just remove the seat belts altogether?
Old Aug 30, 2015 | 04:23 PM
blue project's Avatar
I unbolted them to fit the piece in then cut a hole for it to fit. I'll see if i can get a picture in the morning.
Old Aug 30, 2015 | 04:33 PM
sbxjunkie's Avatar
Pics would be great! Thanks! I appreciate it. I test fitted the wheel wells today and they didn't seem to fit too well on top at the rear roll bars and at the bottom where they are tucked in on the side/floor. Would you post pics on how yours look?
Old Aug 31, 2015 | 09:17 AM
ID:	623298Click image for larger version
Once the piece in in place and you fiddle with it they do fit pretty well. They just need to be shoved under a lot of the interior trim pieces to make them fit properly. I left mine in the sun for a few hours just to make them more pliable with definitely helps. I did have to cut a hole for my hardtop wiring harness.
Old Aug 31, 2015 | 02:00 PM
sbxjunkie's Avatar
Thanks blue project! I will let them sit out in the sun for a bit and try again.
