35" DuraTrac vs BFG All Terrain T/A KO2 - Everyday Ride Quality ?
Old Sep 2, 2015 | 12:32 PM
jpiggot's Avatar
Default 35" DuraTrac vs BFG All Terrain T/A KO2 - Everyday Ride Quality ?
First off, thank you to everyone who posts to these forums. Days reading these forums have taught me more than years driving my own Wrangler.
About to bite the bullet and move up in size, and the contenders are familiar to all; the DuraTrac LT315/70R17, vs the BFG All Terrain T/A KO2, in 35X12.5R17LT. Very similar tires, similar dimensions. BFG is load rated "E" - Goodyear is rated "D" They really are...well...similar. They both come in black. They're both made of rubber. They go under the Jeep.
Every day ride comfort is a huge consideration; my life dictates that I'm going to be spending 90% of my time driving around town, and only 10% off road. I'm probably never going to disconnect my sway bar. Doubt I'll be rock crawling. Probably put in a 2.5" lift and swap out the wheels, rather than use a spacer on my stock 17" rims. But I'll like the look better; I'll enjoy the increased handling in the rain, and I'll be ready when Atlanta gets 2" of snow and the entire damn city explodes into chaos (sigh) And when I drive into the mountains, I'll chuckle when the cabin rental guy tells me that the road "...is a little rough."
Here's the thing - my instinct tells me the DuraTrac's will give me a better ride on the highway, but I don't like the look as much as the BFG's (they just seem...squat) I know that shouldn't bother me, but it kinda does. It's a preference, and I'm sure others feel differently. From those who know, am I really going to notice that huge of a difference between the two, all other things being equal ? Would adding another piece of equipment mitigate the "E" tires, so they ride like the "D's" ? Am I making too much of this ?
After hundreds of pages, I feel like I've lost perspective - I'd appreciate some of yours. Thanks.
Old Sep 2, 2015 | 12:44 PM
jadmt's Avatar
JK-Forum Ambassador
Not apples to apples but I run KO2 in 34x10.5-17 D rated and Toyo AT2's in 35x12.5-17 E rated and there is no difference on the highway in how they ride. This is on a jkur. Both ride great the KO2's are slightly noisier but not enough to make a wit of difference. I have both mounted on their own rims so easy for me to go back and forth. If I could only have one set no question it would be the Toyos. Maybe if I was running a light 2 door I would have different results but mine weighs over 5000lb. This empty before adding heavy rear bumper and 148lbs of rocker protection and nobody in the vehicle full tank of gas.
Old Sep 2, 2015 | 12:45 PM
fredrok's Avatar
Between the 2, hands down Duratracs for your needs. You can't see the tires from inside anyway.
Oh! And welcome to the forum......make sure you have a flak jacket.
Old Sep 2, 2015 | 01:14 PM
jpiggot's Avatar
Thanks for the welcome. Yes, I'm looking forward to the responses about that "squat" comment
Old Sep 2, 2015 | 02:04 PM
Wildschwein's Avatar
I'm pretty dead set on the Duratrac tires regardless if being back ordered through mid October. They have the highest rain/snow/ice ratings of everything I looked at in 35's. Not sure if that's a factor for you or not, but it was meaningful to me.
Old Sep 2, 2015 | 03:16 PM
doogietj's Avatar
Just went through the same process a month ago. I went with duratracs, the ride is way smoother than my mtrs. Both tires are good my decision came down to tread depth and snow traction. And since every time you walk up to the jeep you'll stare at the tires get the ones you like. Between these two tires I don't think you can lose.
Old Sep 2, 2015 | 03:19 PM
jpiggot's Avatar
Really appreciating the responses so far. Thank you !
Old Sep 2, 2015 | 03:31 PM
2BAJeep's Avatar
After all my research I am going with Duratracs. Either is a good choice just think Duratracs fits my needs better. I have procomp mts right now.... I do not recommend those at all.....
Old Sep 2, 2015 | 03:44 PM
thirdcoastborn's Avatar
Default Ko2
Really enjoy my new 35x12.50r17 Ko2's. Great ride on road, in wet conditions and great offroad so far here in Colorado. Just got back from Moab and they were AWESOME! Let me know if you have any questions. EDIT, I had the old Ko, didn't like them... these are way better. Also apparently a good snow choice. I will see in a few months.
Old Sep 2, 2015 | 03:57 PM
jpiggot's Avatar
Nice, ThirdCoastBorn !! What kind of lift are you running with those ?
